Is it direct way or indirect (after awakening)?
If direct - forget it. You lose your time. Try to get this noise after awakening and you will take more powerful result in few seconds
If it happen after awakening you just need to amplify this movement, take control of it
You shouldn't expect - you should make result. Because there are thousands variations.
Breathing must be calm and out of your emotions.
Re: What should I expect? Noise, lifting, breathing
- Michael Raduga
- Administrator
Re: Entering the phase
- Michael Raduga
- Administrator
Just try to amplify it more and more...
The more strange sensation the more chance to make separation or it will happen itself
- Michael Raduga
- Administrator
Phantom movements are not obligatory in all cases
In this case:
noise
-> bigger noise
-> separation
if not -> more noise
-> separation again
etc.
In this case:
noise
-> bigger noise
-> separation
-> separation again
etc.
