Re: Problems with separation techniques...
Share and discuss indirect techniques, direct techniques, becoming conscious while dreaming, non-autonomous methods
Lev
Newbie
Newbie
Post by Lev »
So I've been attempting to lucid dream for about a month, and I've managed a couple successful and meaningful attempts. I have had one major problem though: complete separation. I've had two successful attempts were made through indirect phantom wiggling, then sitting up, and I've had several where I've become aware in my actual dreams. However, almost every night I come close to separation and fail multiple times. I get to a point where I begin to phantom wiggle and i slowly feel myself rising above my body, and when I feel I have moved seemingly a few feet from my  body I have tried rolling out, sitting up, and continuing to levitate upwards, which all usually fail. When I attempt to roll out, I feel the initial roll but I end up resetting my position, and I feel as if I am rising upwards on my back again. When I attempt to sit up my whole body feels like it begins to rotate vertically, and sometimes it rotates to the point where I am upside down, but unable to do anything from that point. While levitating I usually come to an invisible wall that I'm unable to pass. In all these situations I do feel like I'm trying to gain movement as aggressively as I can, yet getting no where.
If anyone can offer any tips or help on how I can overcome this, it would be much appreciated! Thanks a lot...
Michael Raduga
Administrator
Administrator
Post by Michael Raduga »
Two good tips for you:
1 - It seems like your phases is not deep enough for easy separation. You can solve it by alternation indirect techniques with separation techniques. Can't separate -> go back to indirect techniques (and make it better!) -> try separate again -> if cannot -> go back to indirect techniques (and make it better!) -> etc
2 - if you feel that your phase is good enough but you can not leave the body, you can try translocation techniques just right in you body (teleportation)
